Why isn't my S6 edge charging?
Hi!
This is my first post. So basically I have a water damaged S6 Edge, and I put it in rice. I left the phone for a day or so. It did not turn on, so I decided to open the phone and clean it with isopropyl alcohol. Once I did that, the phone did turn on and indicated that it was at 96-100%, but when I unplugged the phone, it automatically turned off. Then, I decided to order a battery and charging port connector off amazon. I installed those and the problem is still consisting. I've wiped my cache, but I haven't reset my phone.
Esta é uma boa pergunta?
1 comentário
Well, I managed to remove a yellow transparent sticker and an EMI shield off the board, but the rest of the shields are soldered on, which I am not able to remove at the moment. I also dipped the phone in Isopropyl Alcohol again.
por Yafeat Alemayhu
