Why does my navibot dont switch on?the battery is charged, but no ligh
My navibot Doesn't switch on. The Battery is charged but all lights are off. I tried to Clean it but Nothing changes.
Esta é uma boa pergunta?
@doxdici you will have to disassemble it and take a look at all connectors and check the battery to ensure it is working. A dead battery may appear to be charged but does not hold a charge. Start off with this teardown Samsung NaviBot SR8855 and take some pictures of what you encounter. Post those with your question so that we can see what you see. Use this guide Adicionar imagens a uma pergunta já existente for that.
Use this diagram
to follow the power flow and see if there are any obvious damaged components etc..
Esta resposta foi útil?
Where did you get this schematic?
Your battery is not recognized by device it doesnt turn it self. You need to check battery 14.4-15.5 volt between
Same probleme here, battery ok but navibot death, no lights, notting....! Switch is ok, voltage on the cirquit bord ok.
Are you sure with battery voltage? My battery shows 13.3 V and It`s new...
90% switch on/off, it was very dirty contacts inside, you should change switch
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 24
Duração total: 3,208
