Ir para o conteúdo principal
Auto Brightness settings missing after update.
I recently replaced my Front-Facing camera and Sensor Assembly and also updated to iOS 11 then to 11.0.1 and they moved Auto-Brightness. I found where they moved it to,
Settings> General>Accessibility>Display Accommodations
When I go there it is totally missing from the list. Does anyone else have this issue of it not being there? or is it possible that I just have a bad Front-Facing Camera and Sensor Assembly?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
You did make sure to click on display accomodations and not look for auto brightness on the accessibility page right?
Not sure what would make it disappear as the option should be there even if the front camera assembly is unplugged.
Esta resposta foi útil?
Pontuação 1
3 comentários:
Yes I did. I clicked on it and all it gave me was Invert Colors, Color Filters, and Reduce White Point. It should be in between Color Filters and Reduce White Point and it isn't there. It does say the following where it should be, Turning off auto-brightness may affect battery life.
This is a picture of what it looks like. https://photos.app.goo.gl/yx9aSWC97kDUiV...
por
Then it's probably a bad front camera assembly.
por
Thank you. Looks like I will need to get another.
por
did you solve the issue ?
i have the same problem right now after i replaced my screen .
so if you solve it.. what is the solution ?
Pontuação 1
I replaced the front facing camera, ambient light sensor, speaker, and microphone cable. The ones I was getting from eBay were not OEM and didn’t work so I got mine from iFixit. That fixed my issue.
Pontuação 1
Adicionar a sua resposta
Michael Miller será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 2,465
