Ir para o conteúdo principal
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
915 Perguntas Visualizar todos
My hold switch is not unlocking
I have already taken it apart, with the manual, but cant figure out how to get it going...
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Losa, all you have to is to replace the switch when it is broken. There is really not a good way to fix it The part is inexpensive and easy to replace iPod Video 30 GB Headphone Jack & Hold Switch of course make sure that the ribbon cable is properly attached to the logic board. Good Luck.
Imagem de iPod Video 30 GB Headphone Jack & Hold Switch
Produto
$29.99
Esta resposta foi útil?
Pontuação 2
In my case the problem on an 80G video turned out to be that the white plastic frame that keeps the hold switch external slider aligned to the actual internal switch was broken, so that the external slider lost alignment and contact with the internal switch and wasn't doing anything. There is no replacement part of the plastic frame.
Pontuação 0
Comentários:
May be a cheap replacement back plate would resolve that. Some of those parts are hard to come by...
por
Adicionar a sua resposta
Losa será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,329
