battery charge problems power book 17 g4
after fiew minutes the green led stop and the battery(new) don't charge
Esta é uma boa pergunta?
Download and run Coconut Battery to get an idea of the condition and communication to the battery. http://www.coconut-flavour.com/coconutba...
We're you having this problem before you replaced the battery? Has the new battery ever worked on this machine?
Esta resposta foi útil?
Hi Mayer, thank you and sorry for my orrible english.
I know coconut, the battery is ok. My power book
start with the battery charged. The ac adapter don't charge the battery. I try to unmount the battery but it don't start and the led remain off (no green or orange). I try to change ac adapter but it don't start. It is possible that the broblem is in "DC-In Board"?
thanks
Use a multimeter to test the output of the AC adapter. If it's good, then replace the DC IN port. Here's how to do it: PowerBook G4 Aluminum 17" 1-1.67 GHz DC-In Board Replacement
thank you, i will follow your advice.
All best
Please tell us just what Coconut battery says
it needs to have its “DC board” replaced
I replaced DC board, but nothings happen, the led remain green and battery don't gharge. Whithout battery start only the little ventilator. thanks
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,585
