Ir para o conteúdo principal
Model A1842. Released September 2017, the revision to Apple's 4th generation set-top-box featuring an A10X Fusion processor and 3 GB of RAM.
14 Perguntas Visualizar todos
Does the Apple TV 4K have a fan on the bottom? Just curious.
It looks like (from pictures) that the Apple TV 4K has a vent on the bottom. I’m wondering if it has an active cooling solution (i.e. with a fan) or is just passive cooling (without a fan).
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Really want to see the teardown for this one! A10X with active cooling might be a screamer.
por
Adicionar um comentário
1 resposta
Solução escolhida
Until someone does a teardown we won't know for sure.
I suspect there is a fan and a heat pipe system. Why do I think that? If you review the images you'll see there is no other opening for the air to enter or exit (chimney effect) for a passive system. The air must be coming in on one slot set and exiting on the other side on the bottom being moved by a fan.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Reid Fleishman será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 1,756
