Ir para o conteúdo principal
The RCA Voyager II is a 7-inch tablet produced by RCA.
67 Perguntas Visualizar todos
My screen is stuck on
when i turn on my screen it it stays on the screen that said voyager .
Esta é uma boa pergunta?
Pontuação 18
6 comentários
how do you fix it
por
I did all of that and all it does is turn back off it's still not working don't know what to do at this point HELP PLEASE…..
por
Same here. Piece of junk
por
when the tablet gets stuck on the rca screen how do I fix that
por
how to fix a rca screen
por
Exibir mais 1 comentário
Adicionar um comentário
3 respostas
Pergunta mais útil
Courtney Lord sounds like your tablet has issues with the Android operating system. You may have to try a factory reset by booting into recovery mode. Powered the tablet off making sure you have more than 50% charge on the battery. Boot into recovery mode by pressing and holding the volume up and power buttons. At the RCA logo screen, let go of the volume up button and you should see an android image. Press and hold the power button and tap the volume up button once more and you should be in the recovery mode menu. From here, you will need to use your volume up and down buttons to scroll and navigate to the wipe data/factory reset option and use the power button to confirm. When the process is done, go ahead and reboot and your tablet it should now be set to factory original settings.
Esta resposta foi útil?
Pontuação 6
4 comentários:
I did all the reboot and table hard reset but the keys will not work on my tablet
por
Same thing happening to me
por
I was dumb enough to buy a second rca tablet for my grandson only to have both of them stuck in limbo...the reset does not work on either one...everything was tried just as told but same screen...they will not go to any other screen...
por
It worked thanks!
por
Press the power button, then volume up, then volume down. Then wait.
Pontuação 3
3 comentários:
What if I don't have keyboard?
por
You don’t need a keyboard. Use the PHYSICAL buttons on the tablet.
por
It worked. Had to do it a couple times but it worked. Thanks!
por
What you are gonna want to do is,
  1. Press the power button.
  2. now press the volume up button
  3. lastly, press the volume down button.
  4. so basically, press the buttons going from up, to down.
Pontuação 0
1 comentário:
How long does it usually take to get passed the voyager screen after I do all of that?
por
Adicionar a sua resposta
Courtney Lord será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 17,121
