Ir para o conteúdo principal
Lançado: 4 de setembro de 2014 Modelo: SM-N915A
Phone won't turn back on
So here's what happened; My phone started dying quickly and then started turning off and back on all by itself until it suddenly turned off and now won't turn back on at all. I ordered a replacement battery and the phone still refuses to turn on or do anything at all. What might be the problem? Any advice on how to fix this? Oh also the screen is cracked in one spot but I've never had any problems with the screen.
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
2 respostas
do you know the model of phone you have?
Esta resposta foi útil?
Pontuação 0
1 comentário:
Model # SM-N915R4
por
I have this problem also, ever since the June security update. The local Samsung Experience Center was unable to fix and suggested sending to the repair center. I decided to pass on this suggestion.
HOWEVER, this is a fairly common problem as documented on the internet (with no solutions as yet). You should be able to restart the device by removing the battery for 10 minutes and then reinstalling and starting. The problem will probably reoccur when you turn off or restart the device. There's an app called WakeLock that keeps the CPU running and prevents the freeze - but does drain the battery faster.
Good luck.
Pontuação 0
1 comentário:
I’m having the same issue to add to that my battery gets hot when charging. This also the message I am getting when powered up.
Recovering booting…..
Recovery is not se android enforcing
Set warranty bit: recovery
It stays like this and nothing else happens.
por
Adicionar a sua resposta
Nina Borseth será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 15
Ao todo: 2,578
