Ir para o conteúdo principal
The phone won't charge after battery overheating
the phone has stalled during use and the battery has overheated, when the charger is plugged in i get the message: battery alert... the battery temperature is abnormal,charging has been stopped.
Esta é uma boa pergunta?
Pontuação 2
4 comentários
@rosioaratudor Have you tried turning off your phone for a few hours until the battery is cool, and then turning it back on? and doing what you just did before?
por
Battery paused exceeded ideal temperature range
por
Yes it has refused to turn on completely
por
I have tried all the above questions
por
Adicionar um comentário
4 respostas
Pergunta mais útil
Try leaving the device off for a day or so.
If it does not work:
Consider getting it repaired for a battery replacement. Remember to not play with it on for too long, turn it off if not playing and do not overcharge it.
Esta resposta foi útil?
Pontuação 2
Over heating won't charge
Pontuação 0
I found a 1.1kohm dead rezistor on pcb near the battery connector ,i replaced and work fine.
Pontuação 0
I have not found the right help for my phone
Pontuação 0
Adicionar a sua resposta
Tudor Rosioara será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 19
Duração total: 3,475
