Ir para o conteúdo principal
Scientific calculator by Casio. Widely used by students world-wide due to its great quality for the low price.
32 Perguntas Visualizar todos
Not working. No display. Better also changed. what should I do?
My Casio fx991 es plus calc not working what should I do? No display battery also changed. Advise me please.
Esta pergunta é pertinente?
Pontuação 11
14 comentários
My Calculator display is gone. How can I repair it
por
Not working properly only working solar power not working on
por
It is not working and displaying.
por
Not working and not displaying
por
CASIO fx-991ES not working even though replacement of Battery. But its working with solar. pls suggest any things for resolve.
por
Mostrar mais 9 comentários
Adicionar um comentário
7 respostas
Pergunta Mais Útil
same problem occured my casio fx-991es plus. i changed battery same problem occured not turn on my calculator but working while solar. so i opened my calculator i check the wire connection solar wires are connected properly and battery black wire it mean negative line cut down. i fixed that issue now my calculator working finely. thanking you.
Esta resposta foi útil?
Pontuação 2
5 comentários:
Can you please tell me How did you you fix the issue
por
Same problem can u say me clear procedure
por
can you please tell me in what place where the black wire should be connected? thanks in advance
por
I had the same issue, replaced battery but still didn't work but it works on the solar panels if flashed with a light source. I opened my unit and what happened to my calcu was the black wire were slightly corroded and a with a touch it suddenly snapped at the soldered point. I soldered in back in place and it came back to life.
por
You re lie I am calcalater man I rip all tha calcs thats what us pros call the calcualtors dont worry I can help at all points just come to address here namaste fremnd Dundrum Rd, Friarland, Dublin 14, D14 W0V6
por
@shah313 double check to see if there is a reset hole on the back of your calculator. Use a small object to depress the rest button in there. Let us know what you find.
Pontuação 0
3 comentários:
Thanks for your answer but my calculator still at same position.
por
I pressed the button but still, nothing happened.
por
Thanks for ur answer my calculator start working
por
On the back there will be a “P“ button in the middle. Press it and see if there is a difference.
Pontuação 0
I saw that the calculator was solar, so then I took my device and turned up the brightness and faced it to the front of the calculator. It started turning on
Pontuação 0
1 dos comentários:
I most likely shouldn’t have been doing my assignment in the dark in the first place ^3^
por
As it’s screen is not showing anything; Consult with any technical expert as there may be some internal faults which can’t be solved verbally.
Pontuação 0
Same thing also happened with my calc. So i was searching for the reset button but couldn’t find any at the back. So what i did was i tapped the calc around the solar plate area with my fingers three four times and then pressed the power button. And it turned on.
Pontuação 0
1 dos comentários:
I dont know how , but your method worked :lol
por
I had this problem too I opened my calculator still couldn't figure out what was the problem so what I did was my cal works on solar power as well so I turned my cell phone flashlight on and I held my calc display in front of the light and it worked it's not supposed to work when I light is
Pontuação 0
Adicionar a sua resposta
Shahzad será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 14
Últimos 7 dias: 110
Últimos 30 dias: 624
Duração total: 39,639
