Ir para o conteúdo principal
The Lenovo Yoga 710-14IKB was released August 2016. Model name 80V4. 14" touchscreen convertible laptop by Lenovo.
18 Perguntas Visualizar todos
How to reset the battery without removing back cover?
Hi,
My Lenovo Yoga 710-14IKB it was not turning on, I removed the back cover and unplug the battery and plug it again and it was recovered, But I would like to know if there is a way to reset the battery without unplugging it removing the back cover
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@yelidominguez no there is not. Removing the cover is the only way. The issue I have with that is why you have to do this. Your Lenovo should still be covered under warranty, so let them check it out and make replacements as required.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Yuri será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 2,114
