I can't access my files
Why can't I access my files it say something is turned off or not installed?
Esta é uma boa pergunta?
The only thing I can think of without seeing the device is that one of the main programs that utilizes whatever you're are attempting to open is disabled OR needs to be updated in the play store.
If you go to settings > applications> and look for the disabled and/or check for a software update, check the play store for application updates that may run the file you're attempting to open.
The only application I can think of for the S5 is either called Memo/Notes.
Esta resposta foi útil?
It works now thanks
Glad to hear it!
Thanks iowloakkalsl
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,415
7 comentários
Can you be more specific about what you are trying to access
por rohith rangaraju
If I go to settings look in storage at explore nothing that I try to open will says it's turned off or not installed
por Bill
What's turned off or not installed? We can't see what you can, so you'll need to give us as much information as possible.
por George A.
@pccheese you're doin great, kid. Keep goin
por iMedic
@bmur98, do you see a "My Files" app in the phone? That can view your files and open your folders normally.
por S W
Exibir mais 2 comentários
