Ir para o conteúdo principal
Lançada no Japão a 12 de Dezembro, 2004, na América do Norte a 24 de Março, 2005, e na Europa a 1 de Setembro, 2005.
PSP 1000 won't charge
My PSP that hasn't been used and turned on for a long time made its battery dead...before this ,I had no trouble charging it even when I barely used it..recently I tried charging it with its charger but its not charging..the charging light doesn't appear when I plugged it in...I do not know whats wrong with the charger..looked up all the videos and sites..nothing's working
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Hi my psp 1000 was working earlier today and charging and for some reason now I put the charger in it was orange and then flickering and just turned of I changed the fuse and still nothing anyone got any ideas
por
Adicionar um comentário
3 respostas
Solução escolhida
Hi!
Try borrowing a charger from a friend, see if that works. If it does, it means that you'll have to replace yours, otherwise report back here and I'll help you with this problem.
Esta resposta foi útil?
Pontuação 2
I have same problem ! Tried with a good charger and battery and still charging light does not turn on!
Pontuação 0
Pontuação 0
Adicionar a sua resposta
Howtohoe será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 44
Ao todo: 765
