Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
Screen doesn't work after replacing screen
I just replaced the screen on iPhone 7 and when I put everything back together the screen won't even light up... I don't know if it's the phone or the new screen... it was fairly simple to make the connections and I double checked them again and they seem to be seated properly... any thoughts or answers?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Did you unplug battery before doing the repair?
Sounds like either faulty screen or backlight filter blown.
If you don't see display at all then it's probably faulty screen.
If just very dim display then backlight filter is most likely blown and you would need to bring it to someone that does microsoldering for it to get repaired.
Esta resposta foi útil?
Pontuação 3
1 comentário:
Thanks- Definitely not the backlight filter since absolutely nothing shows on display... I double checked connections and still no display so hopefully it's a bad screen and not a bad phone...
por
Most common fault---bad screen. Second most common--long screw damage from overtightening or mixing up the screws.
Pontuação 2
1 comentário:
So if I would have the wrong screw in the wrong spot will that damage the phone or will it correct itself after removing the screw? I removed all the ribbon bracket screws and tried the screen but it still doesn't work... I'm hoping it's just a bad screen... but really have no way to tell.
por
Adicionar a sua resposta
Rodney Hostetler será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 169
