Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
178 Perguntas Visualizar todos
New Logicboard Stopped working
So I was removing my old logicboard which had a bad headphone jack. And I bought a new one. I took it out of the iPad it came in tested it and everything. Worked fine. I put the iPad together set it up and it just stopped. And I was careful where I put everything. And handled the logicboard with care.
Esta pergunta é pertinente?
Pontuação 0
Comentários:
Are you getting any proof of life? Have you hooked it up to your main syncing iTunes?
por
I have hooked it up to itunes. But nothing is showing up
por
Adicionar um comentário
Kits para Nintendo Switch
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
1 Resposta
Old logic board had headphone jack problem. That can be repaired.
Where you bought the logic board from?
Have you checked the voltage in Tristar ?
Esta resposta foi útil?
Pontuação 0
Comentários:
Got it from eBay. Was actually part of an iPad mini that had no display. Just the internals. $110 I guess if it doesn’t work today I’ll return it
por
That's ok
But why don't you just change the headphone jack on older one.
por
Adicionar a sua resposta
Antonio Kozak será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 39
