iPhone stuck on Apple Logo after screen replacement
Hello,
I'm hoping for some advice on what could possibly be the problem with my iphone 6. I recently dropped my phone and had a cracked screen. The phone still functioned properly and after finding a repair shop with good reviews I took it there to have the screen repaired. They replaced the screen but after awhile it got stuck when I tried to take a screen shot. so I took it back to the shop and they replaced the screen again, I thought that it was working fine until I tried to use Siri and it didn't work, I did some research and found out they probably had the microphone hole covered so I took it back to the shop again. I got a call from them telling me that they had to reset the phone and that it was stuck at the apple logo. I decided to take it to apple themselves and they suggested to buy a new phone which I did. I want to fix the old phone and wondering what could possibly be the problem. I've reset the phone, it gets stuck with the apple logo, however when connected to iTunes it shows up in the devices section but on the phone screen it's just stuck at the logo. Please help me with a possible fix so I can try to get it running again.
Esta é uma boa pergunta?
3 comentários
At any point did the repair shop you took it to, or Apple, try to restore the device? Steps are in this article:
https://support.apple.com/en-us/HT201252
If they did, was there any kind of error message? The concern could be an issue with the logic board.
Sorry I don't have much else, but I hope this helps in some way.
por Matt Foust
I tried to restore it, putting it into DFU and then restoring it completely. It would go through the restore process and then it would show in iTunes as a device but then had an error and couldn't complete the restore.
por Terin Albritton
so the answer that the apple genius bar gave me about the logic board being bad never did sit right with me because the phone would be recognized by iTunes and windows when connected. So I thought I would troubleshoot further and decided to buy some tools and open the phone myself. After disconnecting each cable from the logic board and then reconnecting them, I found out the problem was the front facing sensor and camera cable, I booted up the phone with that cable disconnected and it started up fine. Shut down the phone and reconnected the cable and it works. The mic is still not working so I'm going to replace the cable and hopefully have a working phone again. Thanks for all the help and suggestions, much appreciated.
por Terin Albritton
