Charge indicator LED permantly on
I have an Alcatel One Touch 4015X (I believe its commonly know as a Pop C1) that maintains the charging indicator LED permanently on.
This started after replacing the original battery. After two charging cycles , the phone stopped receiving charge and the charging indicator LED will no go off.. When connected to a charger, it indicates it is charging but it actually consumes more energy, spending about 5% to 8% battery every 10 minutes.
The battery is an official Alcatel replacement part.
I tried replacing the original battery but the problem persists.
There is no apparent damage to the charging port.
I have tried another charger, with no success.
Connecting the phone to the computer allows me to access all USB functions but even if set to charging mode, no charge goes to the battery.
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Comentários:
Are you that "charging mode" isn't supplying power instead of charging itself?
por
Adicionar um comentário
Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
Visite Nossa Loja
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
3 Soluções
Solução escolhida
Battery's bunk. Get a new or replacement one from where you got bunk one
Esta resposta foi útil?
Pontuação 3
Comentários:
Reverted to the original battery and the problem persisted.
I only got the replacement because its life time was getting very low, about 3 to 4 hours long on stand by.
por
So you still don't have a known good one? If the battery isn't the issue then it's the charging circuit. We may have a guy here for that
por
I was able to get the new battery tested on another phone that uses the exact same battery model and in that phone the battery took up charge so yes, the problem may reside in the charging circuit.
How can I get a hold on the person in question?
por
@refectio they've requested an audience with your awesomeness!
por
Thanks.
I'll drop the guy a line.
por
Mostrar mais 2 comentários
Install this app, charge it a few times and check your battery health:
https://play.google.com/store/apps/detai...
Then tell us what it says.
Pontuação 1
Comentários:
I'll do this as soon as I can and post back some data.
por
The phone is too old and is not supported by the app.
Thanks for the thought, tho.
por
Try to change the battery
Pontuação -1
Comentários:
Again? The original only got replaced because it was getting very short lived, even on stand by, and after reverting back to it, the problem persisted.
por
Adicionar a sua resposta
Qyron será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 42
Todo: 385
