Ir para o conteúdo principal
Repair guides and support for laptops manufactured by MSI.
The Monitor is Failing; How to Fix
My MSI Ghost screen has started to have failing. The screen sometime goes green momentarily and then comes back to what it used to. When I raise the computer in an angle it works perfectly but when its parallel to the surface it start failing again.
Update (08/25/2017)
MSI GS60 Ghost Pro-002 15.6" SLIM GAMING LAPTOP GTX 970M i7-6700HQ 16GB 128GB SSD + 1TB WIN 10 THUNDERBOLT STEELSERIES KEYBOARD
is the laptop.
Its kinda of an expensive laptop so any tip would be much appreciated.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
This may be a cable issue more than a LCD issue . If changing the angle changes anything it leads me to believe the issue is where the cable passes between the hinge and the housing. Replace the cable and if the issue continues then replace the LCD . If you were to include the model number we could possibly provide more detail on fixing the issue. Hope this helps
Esta resposta foi útil?
Pontuação 3
4 comentários:
por
Not exactly the problem, but still extremely helpful nevertheless. I do agree its is the cable.
por
A total teardown is required for a cable . be very careful when routing the cable back through the hinge so you don't have to do it a second time
por
Adicionar a sua resposta
julio Cubillas será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 1,287
