Screen door won't close completely without my lifting it into place.
Screen door won't close completely without my lifting the closing pieces into place. Can this be fixed?
Esta é uma boa pergunta?
This is very common. Usually the door drops. First tighten the upper hinges and see if that pulls it up. If not you may have to put a shim on the lower hinge to push it out. When doing that I would start with an 1/8" shim and try it with the screws out and see if it is enough. If not add another one until it gets aligned.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 25
Últimos 30 dias: 132
Duração total: 3,059
1 comentário
Thanks ever so much. So nice to have the screen door fixed!
por Jane
