iPhone 6s plus heat problem
With the cellular being turned off as well as the background apps, I can still feel the heat from the phone. Also, there is thick case on it. Does someone have similar issue like mine?
Esta é uma boa pergunta?
You could have a battery problem you should try to feel which part of the phone heats up and if you can repair it or give it into a shop.
Esta resposta foi útil?
I think it is the battery part. Maybe something wrong with the sensor. One day in winter, my phone shut down by itself saying no battery. Then, I plugged the charger in and it shows 21% battery left. FYI, I was in my car and it was pretty warm inside.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 88
