Ir para o conteúdo principal
Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
779 Perguntas Visualizar todos
MacBook is freeze. Lines on the screen
Hi.
Have this Macbook Pro (A1278, early 2011) in for service. It seems to work fine, but after some minutes of use it freeze and there come some horizontal lines on the screen. The mac also starts biping.
I´ll add a video that shows the problem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
There was a class action law suit on the GPU on this model, then a repair program which has since expired.
MacBook Pro Repair Extension Program for Video Issues
https://www.apple.com/support/macbookpro...
(see the bottom of the page)
So it is a well known issue. A lot of success has been had using a hot air work station to reflow the GPU. There are also several companies offering repair service of this model on eBay that will attempt repair or replacement of it.
Esta resposta foi útil?
Pontuação 3
2 comentários:
Thanks for the answer :)
por
In my opinion a reflow is a temporary fix and dosnt solve the problem, what really needs done is a replacment gpu soldered on as chip is damaged and heat makes it appear fixed in most cases
por
That Looks like the gpu is either faulty or it is overheating and needs fan claened and probably new thermal paste on gpu
Pontuação 2
1 comentário:
por
Adicionar a sua resposta
alex será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 7,614
