Pular para o conteúdo principal
The Samsung Galaxy Tab 2 10.1 is a 10.1-inch Android-based tablet computer and belongs to the second generation of the Samsung Galaxy Tab series.
129 Perguntas Ver todas
It keeps switching off when charging and when turning on
Good day,
I have a Samsung Galaxy Tab 2 10.1 (GT-P5100). It turns on where it shows Samsung Galaxy Tab 2 10.1, waits 5 seconds then turns off, the same when putting it on charge, it shows the charger is connected, then black screen. I have replaced the battery, thinking it might have been a faulty battery, replaced charging port and ribbon cable, unplugged all the other ribbon cables, like rear and front facing camera's, audio jack, speakers, still nothing. I also reinstalled the firmware, thinking it might be the firmware that is corrupt
Does anyone have a fix for me, or is it the motherboard?
Thank you in advance.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
kits de reparo de baterias de iPhone
Only $29.99
Buy Now
Only $29.99
Buy Now
1 Solução
What happen when you put the tablet in download mode by pressing volum up home and power, and do the tab restart back on again when it turn off, what about when you put it on charge while off did I show any charging sign, let me know
Esta resposta foi útil?
Pontuação 0
Comentários:
In download mode it stays on, when you install a new firmware with Odin and it auto restarts it does the same, it shows the Samsung Galaxy Tab 2 10.1 and turns off. When I plug it in to charge while it is off it shows the battery sign with a buffering circle and then turns off again.
por
Adicionar a sua resposta
Ewald Majewski será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 30
Todo: 474
