Ir para o conteúdo principal
Repair guides and support for the seventh generation of Ford F-Series trucks. Models include the F100 (discontinued in 1983), F150, F250, F350, and others.
22 Perguntas Visualizar todos
3 Relay's colors gray, brown, green, wiring diagram
1985 Ford F250 extra cad 2x4 460 4 barrel carburetor 2 gas tanks with a C6 transmission there are 3 Relay's colors are EEC Gray, Gas Green, Secondary Gas Brown, two of the relay's located on driver side firewall and the other one is located on driver side fender I'm looking for the wiring diagram for those three realy's I pulled the realy's off from were they connect into the wiring harness themselves and the connectors that connect the realy's to the wiring harness ware very brittle and some of the wires from the wiring harness fell out of the connectors that the realy's connect to the wire harness so anybody can help me out there with this wiring diagram very well preciate it Thank You
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
@jrjrjrjr post some picture of where they are located what they look like and what the damage looks like. Use this guide Adicionar imagens a uma pergunta já existente to add images
por
Adicionar um comentário
1 resposta
i think the link i am giving will provide the wiring diagram you want this is a safe and secure link i also got the help from the link to solve my problem http://toolsnyou.com/
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Joey será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 630
