After Screen & Flex Cable Replacement Ambient Light Sensor Not Working
I recently replaced the screen on my iPhone 7 Plus. During my initial attempt I permanently damaged the (double bonded) flex cable for the speaker, sensors, & camera so I ordered a replacement.
I got the replacement for that flex cable a couple days ago and installed it. Everything is working (camera, speaker & proximity sensor) except for the ambient light sensor. On the original screen I noticed that there is a white filter that I did not see an easy way to transfer to the replacement. Is this filter necessary for the ambient light sensor to function properly or do I possibly have a bad sensor and need to seek a replacement for the cable?
Not having the ambient light sensor working is not necessarily a show stopper but it would definitely be nice to be back to having a fully functional phone.
Update (08/10/2017)
Well, after transferring the filter over to the new display it still doesn't seem to be working. In fact, it seems to be getting random values from the sensor. If I turn auto-brightness off and then back on it will settle at different brightnesses at different times. Very weird.
Anyway, I called the seller and they are sending a replacement. Crossing my fingers that it will work correctly.
Update (08/21/2017)
I hadn't updated my post. Life has kind of gotten in the way. I received the replacement part and it's actually worse than the original. Not only did the ambient light sensor not work but the front speaker didn't work. I had to change back to the original replacement and just deal with no automatic screen brightness.
Part of me wonders if something got damaged on the board? When I was swapping in the replacement part I noticed that part of the foam surrounding the socket might have been pushed into the socket. My eyes aren't as good as they used to be for focusing on small things and I don't have a microscope to ensure the socket is completely clean of foam or glue but nothing changed after I pushed the foam back. I'm hoping that nothing got fried on the system board. I did make sure to disconnect the battery during my repair. It was always the first and last thing to get disconnected and reconnected.
Esta é uma boa pergunta?
Keep the community posted. You could also change your edit into an answer (which you can then accept) so that people who see this in the future understand what solved your problem.
por Minho
This is nothing to do with the problem what you have written about
por Taza
