Why is my HDMI output not working?
My PS3 slim was running as if it was superior to PS4 (that was a hyperbole). Once suddenly the HDMI output stopped working after 2 months of not playing. Then, I changed to an SD for some time and then got a new HDMI cable. It worked.
After almost a year of well working, Suddenly the HDMI output stopped working when I was playing Minecraft. I tried using a new cable, but this time it didn't work.
I searched a lot of IFIXIT forums and all around google. Everyone said,"hold the power button till the second beep." A guy also said that you should handshake,i.e. reset the video setting for a million times around (a hyperbole). I did try all of these but the problem didn't get resolved. SD output's rendering is very poor on my TV that if I see 10 building in HDMI assassin's creed 1, I see only 3 in SD.
How do I fix it?
Should I consider visiting a Sony centre?
Esta é uma boa pergunta?
7 comentários
I have the same problem too!!! Except that I just woke up and tried to use the cord. My High Definition Multimedia Interface cord won't work! I even tried switching slots!!!
por Gameplayer Jacob
My PS3 was dropped down now it's no longer showing on any output. No dry joints or cracks on the board. Please help
por Emmanuel Chirwa
what do you mean dropped down? You're best idea is first start your own question not comment on someone else's
por Zerocool278
My new PS3 (I replaced coz this problem wasnt fixed) Is showing the same problems. Please Help.
por RishiNandhaVanchi
Am having the same problem but when connect using the avs it works just fine but the hdmi port doesn't display anything. Ps help
por Jaston Gondwe
Exibir mais 2 comentários
