My phone won't charge
My phone had 1 percent battery, I plugged it in the charger and charged it all night and when I got up the next morning, it still only had 1 percent battery.
Esta é uma boa pergunta?
First try charging the phone with a different cable. If that doesn't work check the lightning port for any residual lint. Power the phone off and stick the end of a paper clip into the charging port to remove any debris. If that doesn't work the next step is replacing the lightning port, then the battery.
Esta resposta foi útil?
how do i change the lightening port when all else fails and is it possible to charge it wirelessly???
Turn off you phone when charging . Use another flex cable or charger to have a try.
17 hours from now by JennyMay Roma Witters Murrin
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Ao todo: 1,858
