Ir para o conteúdo principal
Repair guides and support for laptops by Lenovo.
2556 Perguntas Visualizar todos
My Lenovo Mouse isn't working right
My mouse suddenly stopped responding when i moved it and the red light scanner for movement is turning on. The mouse registers that it has power because the lights on the mouse turn on if you hit a couple of its buttons. The mouse also doesn't automatically turn on its lights. None of the buttons on it work either. I have tried blowing the the USB connector but that didn't help i tried force connecting the mouse the the computers settings but hat didn't work i also tried turning the mouse on and off but nothing happened and finally i tried unplugging my mouse from my computer but that also did not help i am at a loss i don't know what to do please help me
Esta é uma boa pergunta?
Pontuação 8
2 comentários
i have this problem too and it won't
freaking work :(
por
i think i have this problem i have a lenovo gaming mouse
and yesterday i cleand my desk but suddenly about 2 hours later
it just moved by itself and clecking somethings thin also roblox turned on by itself and today same thing happened it didnt respond at first but i unplugged it then i plugged it again but after i plugged it in
i wasn't able to click anything i turned off my laptop then started it again
then it worked perfectly
if someone know this problem or know how to solve it please reply
ideapad gaming lenovo mouse
por
Adicionar um comentário
2 respostas
Pergunta mais útil
This may be a driver issue. Depending on version of Windows, right click on the Start button and select Computer Management and then select Device Manager. Check to see if your mouse is listed under Human Interface Devices or Mice and Other Pointing Devices. Right click on the mouse entry and select uninstall, if you are prompted to delete the drives click yes. Click on the Actions tab at the top and select Scan for Hardware Changes. This should update the driver for the mouse.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thank you- what if the mouse isn’t listed but it’s been working fine all along, and now suddenly it’s not. Devices are updated as far as I can tell. Batteries are changed too!
por
I had to charge my computer so I can study for my quiz and I turn it back on so I can do my homework and the mouse stopped working I don’t really know what the problem is I just need a solution to fix this
Pontuação 0
Adicionar a sua resposta
Kira será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 32
Últimos 30 dias: 188
Duração total: 23,285
