My touch screen doesn't work
I have tried a force reboot but it still doesn't work I need help!!
Esta é uma boa pergunta?
sounds like a bad digitizer consider replacing or invest that money towards a newer iphone
Esta resposta foi útil?
I have replaced the screen so do you think i need to get another one ?
Is this after a screen replacement the touch didn't work, or did it just stop working the original screen? If it just stopped working, then you will probably need a screen replacement.
I had replaced the screen because it was cracked
Replace the screen.do not try it yourself if you are beginner.iphone 4 screen replacement need some set of skill to replace.
I have replaced the screen but it doesn't work
ok,is there any repair shop near yourplace? if yes ask them to bypass their screen a few to make sure that it is really logicboard problem. sometimes parts we bought are defected/malfunction during shipment.
The LCD may be bad. Have you tried a new screen or "tester" screen?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 80
