White Screen of Death (WsoD) is a famous error that generally related to an issue with OS and it stops the device to do any task as it displays white screen. This issue occurs especially on those iPhone/iPad that was locked due to fail of hardware component, severely dropped or when the upgrade fails .
Every iPhone/iPad users want to get rid of this error ASAP but how?
Well, you should follow the below ways to fix WSOD error on iPhone XR/XS/XS Max/8 and many others:
Way 1: Check screen magnification is disabled
To check this problem and to fix it, use you three fingers same time and double click on screen. This will help you to bring back the screen to normal if it is a zoomed. Now, to switch off the feature, go to Settings > General > Accessibility > Zoom > Off.
Way 2: Charge your phone properly
Way 3: Force restart your iPhone/iPad
Way 4: Restore iPhone via iTunes to fix WSOD error
Way 5: Switch off Auto brightness on your phone
Way 6: Use Recovery mode to fix WSOD error
Way 7: Remove battery from iPhone
Way 8: Enter into DFU mode to fix WSOD error on iPhone
Way 9: Use iOS System Repair to fix White Screen of Death on iPhone
All the above methods are effective but still some users tell that they are not helpful in getting rid of such error. In this condition, it is recommended to use professional tool like iOS System Repair to solve WSOD error on iPhone XS/XS Max/XR/8 etc.
3 comentários
So you haven't taken it apart right? This just happen randomly?
por Chase
You should try this fix [DFU mode].
1. Open Itunes and connect your iPhone to your PC/Mac
2. Press and hold the Home button and the Sleep/Wake button all at the same time.
3. After 10 seconds release the sleep/wake button.And continue holding the home button. Keep holding the home button until you see a message saying "iTunes has discovered an iPhone in recovery mode, you must restore this iPhone before it can be used with iTunes". There you have it your if is in DFU mode.
Or read this guide "Fix iPhone White Screen of Death"
por pattonki
It is not work
por Sofia
