Ir para o conteúdo principal
Model A1288 / 8, 16, or 32 GB capacity
451 Perguntas Visualizar todos
Do I remove the plastic film from the replacement front panel?
On the back (inside surface) of the replacement front panel for the iPod Touch 2nd Generation, I have found that there is a plastic (protective?) film. The plastic film has a tab that extends underneath the front panel data cable. The tab seems to be begging to be grabbed to remove the protective film.
Do I remove this plastic film from the back of the front panel prior to installation or will that destroy the touch screen?
Thanks,
Jeff G.
Esta é uma boa pergunta?
Pontuação -1
1 comentário
Yes, you do want to remove it. LCD's get those as protective covers prior to being shipped. good luck
por
Adicionar um comentário
2 respostas
Solução escolhida
yes remove it. there should be a little tab, be careful not to pull off the digitizer. the plastic you are talking about should have a little die cut mark around it, am i correct?
Esta resposta foi útil?
Pontuação 0
2 comentários:
Yup, that's the one. Silly me had that on for 6 months...
por
but I bet your screen looks brand new :) best wishes...
por
Alright, but can we actually get a real answer about the repercussions of leaving the film on vs removing it?
I always remove them, but am just curious to what would happen if you don't.
Pontuação 0
Adicionar a sua resposta
Jeff G será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 7,610
