Ir para o conteúdo principal
Is this salvageable? (decent external damage)
Hey, my old iPhone 6 got run over by a snow groomer (lol) and got pretty rekt. The internals appear to be intact except for the charger doesn't seem to be connected/functioning as I can't turn it on. Screen is a total loss, except maybe the home button? http://imgur.com/a/pbWMT
Update (07/25/2017)
Ordering a charging port to see if this will let me turn it on, or if some other internals are damaged too. I'll keep this thread updated when the charging port arrives on Friday.
Update (07/28/2017)
Found the culprit. Not going to replace yet as the case is so bent that I'm worried I would break the replacement part. Looks like the ear speaker as well as the home button are in tact as well, so it shouldn't be too expensive to replace the rest. i'm not going to replace the battery as it is unbent (except for like 3-5 degrees the last for mm) and completely fine, unless you guys think it is imperative.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
It's not imperative if it doesn't look damaged or perforated. Maybe keep a close eye on it when you plug it in and if it overheats quickly disconnect it and dispose of it properly.
No need to mount the dock completely for a brief trial, you can leave it loose but be careful not to short any component in the process and not to move anything once is plugged in.
por
Adicionar um comentário
2 respostas
Solução escolhida
Well warped but it seems right in the middle. The lightning dock is probably damaged but it's not an expensive repair. Battery might have been damaged as well. You're maybe in luck and apart from the housing, screen and those two parts the rest is fine..can't see top part from the pictures.
Try replacing battery and dock and see what happens.
Esta resposta foi útil?
Pontuação 4
Maybe you can change the charging port, Lcd assembly replacement parts, front camera and battery to have a try and it will costs less than 100 dollars. As the backhousing is deformation so the LCD screen may not assemble well.
Pontuação 2
Adicionar a sua resposta
Jacob Mullett será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 93
