Pink rectangle and vertical lines
So my Samsung un32eh4003 TV got wet from a leak in the roof and now when I turn the tv on I get some vertical lines which go away and then a pink rectangle about 6 inches wide will appear in the middle of the screen and not go away. I unplugged the HDMI cable which was wet as well so I am assuming the connector was wet where it plugged in. I tried a different HDMI port as well with the same results and it is still there when I click menu.
Any ideas as to what this could be? Any ideas is appreciated..I was thinking main board because of the wet connector and all that but I am not sure if it is the tcon board or the actual panel itself!
Update (07/23/2017)
Do you guys need more info or suggest anything?
Esta é uma boa pergunta?
