Washer keeps restarting after cycle ends
Your solution to this problem includes "Calibrate the User Interface" I am not clear on the instruction you gave. What direction do you rotate the selector knob when doing this part of the User Interface calibration? How do I get to the 5 steps when you indicate "1st click Fill 2nd click Wash....and so on to the 5th click off.
I installed a new controller and all the cycles work, but in every case, 4 minutes after the cycle is complete, the washer by itself goes to the "Normal" cycle and starts all over.
Esta é uma boa pergunta?
Pontuação
0
This appear to be in reference to another question. Could you please clarify?
por mayer
You answered a question on 08/25/16 regarding a Kenmore washer that would restart after the cycle ends. I replaced and calibrated the electronic controller. That now works for every cycle Your instructions then say "When that is all done Calibrate the User Interface. This is where I am having trouble understanding the instructions. I restart the motor calibrations and get to the point where all 5 lights to the left of the selector knob is located and then get lost. I have no idea what the instructions after , "When rotating the selector knob each click "..... No idea what the reference regarding the use of the term """ means. How do I get to the last part of the instruction where it says "1stclick"," 2nd click" and so on. I have tried turning selector clockwise, counter clockwise and every other combination and still the end result is that no matter what cycle I use, when it is complete , exactly 4 minutes after the cycle ends, the washer turns on in the "normal" cycle and starts all over again.
por Thomas Draper
