Ir para o conteúdo principal
Model A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
212 Perguntas Visualizar todos
Older 21'5 late 2012 iMac will the newer retina 4k LCD work in it?
I'm using older iMac 21'5 late 2012, can I replace the screen with the newer retina LCD?
Please advise,
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
No, unfortunately not. The main issue will be the logic board, which is only capable of outputting HD (1920 x 1080). so even if you could retrofit the display, there would be no way of getting the GPU to output to 4k resolutions.
But aside from that, the imbedded DisplayPort cable, the LCD port and the logic board port are all different between the models. The only similarity is the dimensional size of the machine unfortunately.
Esta resposta foi útil?
Pontuação 3
Sorry no the older 21.5" models use a different interface logic than the newer 4k models.
Pontuação 1
Adicionar a sua resposta
coven será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 277
