Problems installing Snow Leopard on 500GB 7200RPM
I installed the new drive and I'm trying to install the OS from the CD, but it doesn't show the new disk.
Esta é uma boa pergunta?
Start up from your system installation disk, "C" key. Go to the second page pull down menu to Utilities, Disk Utility. Select the drive on the left and set the partition to one. This will format the disk and allow you to install the system. Then just do the software update located under the Apple in the upper left hand corner.
Esta resposta foi útil?
Thanks...that seems to be working.
My next issue is that the latch doesn't open all the way so I need to pop it open gently with the spludger. Any suggestions on how to fix this?
New problem. New question please.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,200
