Ir para o conteúdo principal
Caller can't hear me after port change
I've changed the charging port on a 6s and when I checked it everything was working as it should, now the mic has stopped working on calls. I can be heard when in loud speaker and hands free only, there was a metal shim on the mic at the right of the port that I couldn't get off the old one so I hadn't replaced it. Could this be causing the issue?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
I recommend testing the charging ports before install, most functionality coming from it if possible.
Sounds like a faulty charging port (main microphones on the port not working). I suppose it could of went faulty from being improperly installed (tear in ribbon cable / puncture).
I have replaced them before, but not really sure what metal shim you are referring to.
Are you referring to this in step 46:
iPhone 6s Lightning Connector Assembly Replacement
There is black tape covering a screw hole for a metal cover for an antenna cable.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Hi, thanks for your response. I've done loads of charging ports and never had an issue before, if you look at step 55 there is a spudger on the mic with the metal shim which was missing on my replacement charging port.
por
Adicionar a sua resposta
S2i será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 531
