What is the glue in fixing gasket on cylinder head?
What is the glue or adhesive in fixing gasket on cylinder head?
Esta é uma boa pergunta?
Hello,
Not all vehicles require a sealant when replacing a head gasket. You will want to look in the owners manual for whether or not your vehicle requires a sealant or not. It will give you the specs need to get the job done correctly. When you are cleaning the head make sure you do not use anything corrosive to metal or any tool that could scratch the gasket area. In case you do not have an owners manual I have placed a link below where you can get it for free in a PDF file.
https://justgivemethedamnmanual.com/hond...
Please let me know this helped you!
Esta resposta foi útil?
most head gaskets go on dry as they allow the head to 'slide' during thermal expansion and contraction. Thats why cylinder heads today require a very smooth surface, measured in RA's.
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 782
