Ir para o conteúdo principal
Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
487 Perguntas Visualizar todos
It will turn on but only charge to 50%
My samsung galaxy S6 got rained on, and since then it will turn on and screen looks normal and functions normally, but it will only charge to 50%, but when I unplug it then it dies. Do I need to replace the charging daughter board? If I do, then will the home button finger ID still work?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Both front and back are cracked, between replacing the battery and both front and back glass. Is it cheaper to replace phone?
por
Unless you know how to do a glass only repair, it is usually not worth fixing. If the LCD is black, I would just get a replacement then.
por
Adicionar um comentário
2 respostas
Solução escolhida
Sounds like your battery is failing to due liquid. Any time you get liquid on a battery, you want to go with a new one. I would first try a new battery before replacing the daughterboard. If battery fails, then try the board. That should solve any issues you are having with this device.
Samsung Galaxy S6 Battery Replacement
Samsung Galaxy S6 Daughterboard Replacement
Imagem de Samsung Galaxy S6 Battery
Guia
Nível de dificuldade:
Difícil
40 minutes - 1 hour
Imagem de Samsung Galaxy S6 Daughterboard
Guia
Difícil
45 minutes - 2 hours
Esta resposta foi útil?
Pontuação 0
Both front and back glass is cracked, and bad battery, with all of these repairs, would it be cheaper to replace the phone?
Pontuação 0
Adicionar a sua resposta
Amy ford será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 15
Duração total: 142
