Ir para o conteúdo principal
The fourth iteration of the popular 7" Galaxy Tab line of Samsung tablets.
136 Perguntas Visualizar todos
Can't connect to google play store?
hello everyone i have made it through initial setup on my tablet but when ever i click on the google play store app it asks me to enter my information and i do but then proceeds to tell me that it couldn't connect to google play because it had no connection. I looked it up and come to find out my date and time was way off it said it was jan 1, 2000 so i set the date and time to what they needed to be and i tried to log back in and now it says that it doesn't have a reliable connection to the google play servers. idk what to do now. hope someone can help me with this. I also cleared the caches and data and everything but still nothing happens.
Esta é uma boa pergunta?
Pontuação 15
3 comentários
ok i went to do a system update and it says this in quote "the operating system on your device has been modified in an unauthorized way. try downloading software updates using samsung kies on your pc, or visit a customer service center."
what could this mean?
por
I connected my acc in supercell id then i wnt to connect it back in google play. Can u help me?
por
I believe Google needs to fix this crap. I pay for the internet for my phone. I pay for the internet for my home, and yet I have to use someone elses. Google needs to fix this crap. Someone hacked my Facebook account, has access to all my contacts, my address, my credit card information, DOB. Phone number, gmail, Yahoo Account, even my dogs name! And now I can't even up date my phone. So I can use it to report a hacker. What the !&&*?
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Check out any of these steps and see what best works for you...
1. FIX DATE AND TIME SETTINGS
Google Play Services sync with their master servers to send and receive data,
to do this your device time and date should be correctly set.Follow these steps
>> Go to Settings > Date & Time
>>Check Automatic date & time
>>Or alternatively, you can set time by yourself, just make sure it is correct.
2. CLEAR GOOGLE PLAY STORE APP CACHE
Android OS keeps cache of Google Play Store items in order to quickly serve content
to users and to save bandwidth at same time it might cause some issues and could
be one of the reasons behind connection error.By clearing cache and restarting
the Play Store it will not only resolve the issue but will also
serve you recent/fresh apps for download and purchase
>>Go to Settings > Apps
>>wipe right to ALL
>>Scroll down and tap Google Play Store
>>Press Clear Data button and tap OK
3. CHANGE DNS SETTINGS OF YOUR PHONE OR NETWORK ROUTER
Settings > Select WiFi Network (Hold Tap) > Select Modify > Show Advanced Settings.
  • DNS1 should be 8.8.8.8
  • DNS2 should be 8.8.4.4
4. CHANGE OR RE-LOGIN YOUR GOOGLE ACCOUNT
>>Go to Settings > Accounts > Google
>>Tap your primary Google account
>>Open options from right top corner, click remove account.
>>Now open Play Store, it will ask you to login your Google account again.
If you previously changed the security settings or password of your Google account. You need to update the account settings on your Android device. Also, you can switch to other account.
Remove Google Account in Android
5. UNINSTALL UPDATES
>>Go to Google Play App settings (refer to Step #2)
>>Press Uninstall Updates
6. REMOVE ANY PROXY OR VPN SOFTWARE
>>Go to Wireless & Network, modify your WiFi settings, go to advanced options and remove any proxy servers.
>>Disconnect any VPN connection or apps you have running in background.
7. DELETE HOSTS FILE (In case you rooted your device)
>>Open File Manager App.
>>Browse to root/system/etc.
>>Delete hosts.txt file
8. FACTORY RESET YOUR PHONE/TABLET
(Make sure you back-up your contacts and files before you perform a reset, else you will lose everything.)
>>Go to Settings > Backup & reset
>>Click Factory Data Reset
Esta resposta foi útil?
Pontuação 3
1 comentário:
I agree with one and two but the others are not good answers.
por
Sign into your Google account from settings. Go to settings, then accounts. Click add account, then sign into your Google account using your Gmail name and password. After that, clear the cache of the store by going to settings, apps, google play store, and selecting clear cache. Try opening it.
Hope this helps!
Pontuação 3
1 comentário:
Well, that would be terrific, if I could actually access Google Play store. It shows on the screen, but the "log in" button is inactive
por
Adicionar a sua resposta
Kyle Simpson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 12
Últimos 7 dias: 57
Últimos 30 dias: 258
Duração total: 34,959
