Pular para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
1335 Perguntas Visualizar todos
stuck on press home to update!?
Home button not working. stuck on white screen saying press home to upgrade. tried restarting and plugging into computer. help?
Esta é uma boa pergunta?
Pontuação 0
Comentários:
Tried using DFU mode to restore with the volume button + power method but it keeps kicking out of DFU mode before the restore can start!
por
This seems to be a pretty common problem. Does no one have a solution?
por
<a href="http://www.bangnapi.com">detik com</a> Membaca berita sudah bisa dilakukan dengan cara yang sangat mudah, kapan pun dan di mana pun Anda berada. Anda hanya perlu membawa sebuah handphone tanpa ribet membeli koran atau surat kabar, karena di internet banyak situs-situs berita yang selalu update informasi yang hot dan aktual. Di Indonesia sendiri, ada banyak sekali situs berita yang bisa Anda kunjungi. Dan tentu saja Anda bisa mendapatkan berita hangat dari berbagai macam topik, mulai dari berita kesehatan, politik, sports, pendidikan, ekonomi, sosial, dan lain sebagainya. Selain itu, berita yang tersaji online tidak hanya sebatas berita nasional, tetapi juga banyak berita internasional yang akan Anda temukan. Nah, apa sih Situs Berita seperti detik com ? bangnapi.com
por
Adicionar um comentário
2 Soluções
Resposta Mais Útil
Try a hard reset first of all, on iPhone 7 long press on power and volume down for a few seconds, the phone will shutdown and restart, once you see the Apple logo release all.
Esta resposta foi útil?
Pontuação 5
Comentários:
i did and it just brought me right back to the press home to upgrade. isnt that just a soft reset though? thank you anyway
por
The same issue is happening with me. Austin Harris, what did you end up doing? restore?
por
Long press the top power button to slide to power off. Then turn on. It should prompt you to choose language if you have done a restore. Then you can activate device and turn on assistive touch for home button function.
Pontuação 1
Comentários:
None of those tips helped me .
por
It seems like iOS11 no longer gives you the option to slide to power off after update.
por
I suppose holding volume down + power may help?
Sounds like the only way is to open up the phone and unplug the battery?
por
Adicionar a sua resposta
Austin Harris será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 57
Últimos 30 dias: 311
Todo: 11,218
