Ir para o conteúdo principal
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
274 Perguntas Visualizar todos
Replaced battery and now the laptop won't stay on without charger
I've got an early 2013 MacBook Pro that had the Service Battery notification and the battery was lasting about 30 minutes. I purchased a replacement battery and the appropriate tools, left the laptop on until the battery was very low on charge (<5%) and then proceeded to replace the battery. It took me awhile, but I didn't run into any issues and I got it all back together.
I plugged in the charger and it went to orange indicating it was charging and I turned the laptop on and it booted without issue, indicating 58% battery life. I then unplugged the charger to make sure the battery was working, and the laptop stayed on for about 10 seconds, then just shut off. I plugged the charger back in and the system booted back up on its own and indicated it was still charging. I double checked the battery connection internally and left it charging overnight.
The charge light is now green and once in the OS the battery indicates it is 100% charged, but I'm still experiencing about 10 seconds of run time after disconnecting the charger. I tried a PRAM and SMC reset, and I believe both were successful but I'm not positive on if the charger should or shouldn't be plugged in for the SMC reset so I've tried both.
coconutBattery indicates the new battery is at 100% charge so I'm kind of at a loss for what's going on here, and would really appreciate any help! I'm comfortable with hardware at this level, but I'm not terribly familiar with Macs on a whole so I'm just wondering if I trashed this thing somehow or where to go from here...
Esta é uma boa pergunta?
Pontuação 5
2 comentários:
I'm having a similar problem except mine won't stay on/boot at all on battery. Coconut shows all battery vitals and info (1cycle, 100ish days old), currently at 94.4% but 0W charging (hasn't moved in 3 days). Have rest SMC and PRAM. Wondered if there was a software thing preventing use of 3rd party batteries. Downgraded from Catalina to Mojave. Same problem. Plugged old battery (OEM) back in. OEM charges and runs MBP (but has over 650 cycles and only lasts 30min tops).
por
I have a similar problem. Replaced the battery yesterday, it only charged to 66%. Battery vitals and info (not fully charged, not charging; cycle count 2).
por
Adicionar um comentário
2 respostas
Sounds like you got a defective battery. Usually what's recommended to do with new batteries is charge it to 100% let it die, then again, charge to 100% then let it die. But in your case, could be a faulty battery or maybe you didn't connect the battery correctly. So the 10 seconds that it's on, it uses whatever power is still in the laptop
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thanks for the quick reply! I really don't relish the thought of getting another battery out of this thing, but I'll bench test it the second time around before fully re-assembling it for round 2.
por
The battery has the issues.Just check the battery again
Pontuação 0
Adicionar a sua resposta
Mike Dragga será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 9
Duração total: 1,099
