Pular para o conteúdo principal
Issue with Touch ID, speaker and front facing camera
Have an issue with a 6 plus that is baffling me. Following a screen replacement and a new touch IC Chip. The earpiece speaker, front facing camera and Touch ID no longer work. The home button itself works and I don't get any message about Touch ID not working on the phone. It just doesn't register the finger print. I've checked that the cables are snapped in correctly and I can't see any viable to damage to the ribbon. Any ideas? Cause I'm stumped!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 Solução
When you say new touch IC chip, did you desolder the chip and resolder a new one, or that you think this is touch IC disease related? Or did you mean a new touch ID button was put on this device during the glass repair? In my opinion this is either the home button link cable not being seated to the board properly, and/or that the front facing camera cable was damaged during the repair and needs to be replaced. You should also look for a small metal grounding plate that is located above the touch ID home button connector, right below home button link cable on the original screen, that needs to be brought over to the new screen for optimal touch ID functionality.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Mary Ellen será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 29
