Ir para o conteúdo principal
Comprehensive set of repair manuals for Android tablets manufactured by Samsung, including the Note 10.1 and the Tab.
3018 Perguntas Visualizar todos
What's the deal with residual power in electronic devices?
Just curious as to why the solution for many of these Samsung Tablets that, out of the blue, do not want to turn on, involves just removing the back cover and unplugging the battery and sometimes coupled with holding the power button down for 20 seconds or so, can magically bring life back to the device. Just trying to attain a better understanding of the nature of such issue.
Much appreciated.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
@lpfaff1's answer is correct. When you remove the battery, all processes stop and the memory (RAM) is cleared. When you remove the battery, allow 15 seconds so the capacitors may empty.
Hope this helps!
Esta resposta foi útil?
Pontuação 3
Pergunta mais útil
@alwayslearning, Steve B, Removing residual power in electronic devices, the system is completely removed of power, so there is a hardware reset, no components are able to run and so no power memory remains in components to cause them to continue working incorrectly. Other ifixit volunteers may also have something to add or better explanation. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Pontuação 3
Adicionar a sua resposta
Steve B será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 229
