Ir para o conteúdo principal
iPhone 6 - Audio issues
Hi, I have an iPhone 6 that had contact with water. I used alcohol to clean all connectors and brushed areas that had corrosion and the phone works now. The water seemed to enter from the top, since I found no trace of corrosion near the bottom. Everything functions properly except the speaker. If I raise the volume past the halfway mark it cracks and goes mute. A reboot resolves the issue until I raise it again. Could it be an issue with the dock connector, the speaker itself, or the audio ic U0900?
Thanks.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
It could be any combination of those things. Only way to know is to test fresh components
Sorry i couldnt be more help
Esta resposta foi útil?
Pontuação 1
Yes, purchase a new dock connector and speaker , they are cheap enough and easy to fit.
Pontuação 0
Adicionar a sua resposta
Benjamin Hong será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 52
