Ir para o conteúdo principal
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Perguntas Visualizar todos
Replaced display screen but phone won't turn on?
Replaced the display with an ifixit Replacement screen,
Powered it up to see if the display was fine and it was so I turned it back off again and finished putting it back together and now it won't turn on at all.
I've tried everything, Tried taking the home button out and seeing if that was it, tried charging the battery but the screen wont come back on, Tried disconnecting the battery and reconnecting. Plugged it into the computer and it was recognized but still no screen to put my passcode in, tried disconnecting the display, tried everything.
At my wits end with ideas, hoping there's someone out there with anything!
Thank you in advance.....
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
How did you confirm that it is problem with display screen before replacing screen. Before replacing screen does your iphone power on or not. After power on when you connect it to computer does it recognize by computer or not.
Have you checked your iphone with another battery or not.
Esta resposta foi útil?
Pontuação 1
5 comentários:
Okay so I replaced the original screen that was factory with the phone as it was broken and cracked, yes before I replaced the screen it worked and after i replaced the screen it worked as I previously said I turned it off after seeing that the display powered on and finished putting the phone (home button etc) together. As I also previously said the device was recognized by my computer but I was unable to enter my passcode as my screen won't work.
por
And no I haven't checked it with another battery as I don't have one.
por
Does the old screen still work? Try that one.
Also you didn't mix up the screws for the metal plate that goes on top of the screen connector cables on the logic board right?
As putting the longer screw where it shouldn't be can damage the board circuit traces and cause no backlight / no display.
por
I tried the old screen and it didn't work, I put them in the right order but I fear I may have screwed them too tight, I have since loosened them and I think rehousing the home button may have done damage too :/ Is there any way I can salvage what's on the phone?
por
If I've stuffed the logic board will replacing that with another new screen work? and If I replace the logic board do I lose everything? Thank you so much for your help so far ben!
por
Adicionar a sua resposta
Sheldonemmakate será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 99
