My right joystick is slightly moving up
I've recently bought this used controller, everything else but my right analog stick is fine.It must've been dropped that the stick has to be pulled up if pressed down. While it's stuck down my game is slightly moving up (Example: while the thumbstick is stuck in place, as I'm playing a first-person shooter, the character starts to look up.) Anyone know if I either have to change the thumbstick or there's something inside that's broken?
Esta é uma boa pergunta?
14 comentários
https://m.youtube.com/watch?v=eqHJFEnbZL... The best solution
por wee Ymm
I have the exact same problem, but I don’t know how to fix it
-TheEight
por - TheOfficialEight -
i have this problem too on both sticks
por Justin Poovathingal
This will not Void the warranty. Opening the controler WILL. Best thing is get several Q-Tips and alcohol. Soak in AL then push down in the opening of the JS. Do it several times and getting that alcohol in there. Move your JS back and for a lot. Repeat. Keep doing that for about 4-5 Q-Tips . Remembering to move the JS all around right after the AL goes into the JS. Alcohol evaporates quickly, so let air dry for a little bit and that should help. If it doesn't, but it is better, then do it all over again until it fixes it. If it doesn't help at all you will either need a new controller or to open up the control and cleaning and fixing that way. But, opening the control Voids warranties. So if still under warranty, do not open. ASK FOR replacement. Hope this helps.
por kalenkerby
Do you think nail polish remover would work to?
por Bealuo Six
Exibir mais 9 comentários
