Why is my calling out is not activated
Why my calling phone is deactivated
Esta é uma boa pergunta?
Are you having issues making calls? Are you able to receive calls?
Esta resposta foi útil?
This should be a comment.
Im seeing 3 issues it might be
1. SIM Card- the SIM Card is what gives you cellphone service, over time it will detroriate, due to usage or elemental damage. 1st, try turning of your phone remove the back cover,then battery and carefully remove the card wait 2 mins re-insert and re-assebble turn phone back on, try making calls . This needs to be replaced if this does not work, call your cp or visit their store fees may apply.
2. Network issue- it will happen that your CP (cellphone provider) will have network outages, or elemntal factors such has electrical devices, metal etc. may causee interference can reduce or sever your connection to your CP's network until you reach an area with better connection
3. Account issue if you are in collection (you owe $) with your CP some will completley cut your service other will gradually do it starting with data the outgoing calls then completley. I would call your cp to ensure this is not the case
Well it's a tracphone so they might just be out of minutes
that may be an issue as well
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 39
