Ir para o conteúdo principal
The C720 is a low cost Acer ChromeOS based Chromebook. Released 2014 successor to the C710.
26 Perguntas Visualizar todos
Why won't my battery recharge?
My charger stopped recharging my acer c720 laptop. I got a replacement power cord but it won't charge. If I unplug it the system goes blank. As long as it is plugged in, the computer it works. I can't get into the back of it to see the internal battery. There was a puff of smoke from the back and that was it.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Acer C720 Motherboard Replacement
You can basically follow that guide on how to open it, once in your on your own.
https://www.amazon.com/Acer-Chromebook-B...
There is the new part. The smoke isn't a good thing. It could mean that somthing fried. If the new battery doesnt work, return it and get a new chromebook as your chromebook is toast.
Esta resposta foi útil?
Pontuação 1
1 comentário:
If you wanted to help this person, you'd try to locate what part burned out, test the motherboard to see if it's intact, see if another battery would work. Check to see if the battery poles were matched up correctly, or not--just that could fry a notebook.
por
Adicionar a sua resposta
Carmen Leach será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 416
