Ir para o conteúdo principal
The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
194 Perguntas Visualizar todos
How do I repair these power supplies
There was a know issue on these power supplies but I cannot find what it was. Here was the Apple recall which has expired: http://www.apple.com/support/powermac/po...
I have several units I would like to repair. I know they can be sent off for repair. Any ideas?
Esta pergunta é pertinente?
Pontuação 3
1 dos comentários
I'm still looking for an answer to this one.
por
Adicionar um comentário
1 Resposta
Solução escolhida
This looks like it could be what you are looking for. http://jimwarholic.com/2008/11/apple-ima... and here is a nice alternative repair of the power supply. http://damntechnology.blogspot.com/2009/... Good luck and let us know if this what you were looking for...
Esta resposta foi útil?
Pontuação 5
3 comentários:
Thanks for the try. Those links are about the G5 iMac not the Power PC G5. I've talked to Jim Warholic on this problem and he didn't have an answer
Turkey - I usually don't ask easy question ;-)
por
Ain't that the truth
por
I always forget about all these Mac's being different I always think that there would be some sort of standard :-) So I learned that the G5 and the Power Mac G5 are using different power supplies, correct? Looks like they must be made out of platinum to explain the high cost (I love my cheapy ATX power supplies :-) Now you mentioned Power Mac and Power PC in your comment. Are those interchangeable terms, I mean is this still the same thing or a totally different animal altogether?
por
Adicionar a sua resposta
mayer será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 1,567
