Ir para o conteúdo principal
AT&T Corded Answering System with speaker phone, audio assist, digital backlit display, and caller ID/call waiting.
My phone won't ring on incoming calls
Phone has dial tone and I can call other people but it won't ring when they call even tho the caller hears ringing. On thier side
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Make sure you ringer isn't muted, or that quiet mode isn't on. Also, are you able to hear the other party on the phone if you are able to answer? If not, you may have a problem with the speaker, which in that case, you'll need to replace it. Hope this helps!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Roy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 17
Ao todo: 649
